Samsung ATIV Book 4 Mouse Pad Replacement
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: step 1, image 1 of 3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: step 1, image 2 of 3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: step 1, image 3 of 3
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: step 2, image 1 of 1
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: step 3, image 1 of 2 Samsung ATIV Book 4 Mouse Pad Replacement: step 3, image 2 of 2
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: step 4, image 1 of 2 Samsung ATIV Book 4 Mouse Pad Replacement: step 4, image 2 of 2
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
Daniel
342 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,119
