Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement
  1. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Backplate: step 1, image 1 of 2 Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Backplate: step 1, image 2 of 2
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: step 2, image 1 of 1
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Battery: step 3, image 1 of 1
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: step 4, image 1 of 1
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Track Pad: step 5, image 1 of 1
    • Disconnect the track pad from the motherboard.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: step 6, image 1 of 2 Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: step 6, image 2 of 2
    • Peel the tape on the track pad back.
    • Unscrew the five 2mm screws with the Phillips #0 screwdriver.
    • Rotate the track pad out of the case.
Jonathan Robidoux
196 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 251
