Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement
  1. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Backplate: step 1, image 1 of 2 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Backplate: step 1, image 2 of 2
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: step 2, image 1 of 1
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Battery: step 3, image 1 of 1
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: step 4, image 1 of 1
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, USB Ports: step 5, image 1 of 2 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, USB Ports: step 5, image 2 of 2
    • Disconnect the ribbon connecting the motherboard with the USB ports .
    • Disconnect the speaker from the board
  6. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: step 6, image 1 of 2 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: step 6, image 2 of 2
    • Unscrew the 5mm screws with the Phillips #0 screw driver.
    • Lift the board out of the laptop.
Jonathan Robidoux
196 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 290
