Samsung Ace Casing Replacement
  1. Samsung Ace Casing Replacement, Battery: step 1, image 1 of 3 Samsung Ace Casing Replacement, Battery: step 1, image 2 of 3 Samsung Ace Casing Replacement, Battery: step 1, image 3 of 3
    • To remove the back casing, firmly press down and push towards the bottom of the phone.
  2. Samsung Ace Casing Replacement: step 2, image 1 of 1
    • With the casing removed, lift the battery from the indicated indentation.
  3. Samsung Ace Casing Replacement: step 3, image 1 of 1
    • From here, you can now access the SIM card and model/serial numbers.
  4. Samsung Ace Casing Replacement, Casing: step 4, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  5. Samsung Ace Casing Replacement: step 5, image 1 of 2 Samsung Ace Casing Replacement: step 5, image 2 of 2
    • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
    • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  6. Samsung Ace Casing Replacement: step 6, image 1 of 1
    • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  7. Samsung Ace Casing Replacement: step 7, image 1 of 2 Samsung Ace Casing Replacement: step 7, image 2 of 2
    • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
    • The power, volume, and camera buttons may fall out when separating the front and back casing.
  8. Samsung Ace Casing Replacement: step 8, image 1 of 1
    • Your casing should be separated and the three loose buttons put to the side.
    • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
  9. Samsung Ace Casing Replacement: step 9, image 1 of 2 Samsung Ace Casing Replacement: step 9, image 2 of 2
    • Slowly remove the back casing by gently pulling the ribbon connection.
  10. Samsung Ace Casing Replacement: step 10, image 1 of 2 Samsung Ace Casing Replacement: step 10, image 2 of 2
    • Gently pull on the wires to remove the front casing.
  11. Samsung Ace Casing Replacement: step 11, image 1 of 1
    • Your front casing and front speaker are now released.
Breanne
187 Reputation
5 Guides authored
Cal Poly, Team 6-24, Amido Spring 2012 Member of Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 951
