Samsung Alias 2 Logic Board Replacement
  1. Samsung Alias 2 Logic Board Replacement, Battery: step 1, image 1 of 1
    • Push down on the back cover of the phone, then remove the back cover.
  2. Samsung Alias 2 Logic Board Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. Samsung Alias 2 Logic Board Replacement, Logic Board: step 3, image 1 of 1
    • Remove the (4) 4.2 mm screws from the four corners of the battery slot.
  4. Samsung Alias 2 Logic Board Replacement: step 4, image 1 of 1
    • Use plastic opening tools to peel off plastic Verizon logo tab from the top of the back outside.
    • Note: The tab is stuck on there with glue, this is alright, just peel it off.
  5. Samsung Alias 2 Logic Board Replacement: step 5, image 1 of 1
    • Remove the (3) newly uncovered 4.3 mm screws.
  6. Samsung Alias 2 Logic Board Replacement: step 6, image 1 of 1
    • Remove the back outside casing using the plastic opening tool.
    • Warning: Do Not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
  7. Samsung Alias 2 Logic Board Replacement: step 7, image 1 of 1
    • Pull up on the yellow tab.
  8. Samsung Alias 2 Logic Board Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect connecting cord using tweezers.
  9. Samsung Alias 2 Logic Board Replacement: step 9, image 1 of 1
    • Disconnect rectangular ribbon.
  10. Samsung Alias 2 Logic Board Replacement: step 10, image 1 of 1
    • Remove logic board.
Chris
133 Reputation
5 Guides authored
Cal Poly, Team 12-35, Maness Spring 2011 Member of Cal Poly, Team 12-35, Maness Spring 2011
CPSU-MANESS-S11S12G35
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,752
