Samsung Alias 2 Speaker Replacement
  1. Samsung Alias 2 Speaker Replacement, Battery: step 1, image 1 of 1
    • Push down on the back cover of the phone, then remove the back cover.
  2. Samsung Alias 2 Speaker Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. Samsung Alias 2 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove the two (4.1 mm) screws down the screen.
  4. Samsung Alias 2 Speaker Replacement: step 4, image 1 of 2 Samsung Alias 2 Speaker Replacement: step 4, image 2 of 2
    • Remove the upper casing with a plastic opening tools.
  5. Samsung Alias 2 Speaker Replacement: step 5, image 1 of 1
    • Use soldering iron to melt, and remove soldering joints of the speaker.
  6. Samsung Alias 2 Speaker Replacement: step 6, image 1 of 2 Samsung Alias 2 Speaker Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the speaker from its place.
    • Note: There are two speakers. Make sure you know which one is broken before removing it.
  7. Samsung Alias 2 Speaker Replacement: step 7, image 1 of 2 Samsung Alias 2 Speaker Replacement: step 7, image 2 of 2
    • Use tweezers to insert the new speaker into the speaker slot.
  8. Samsung Alias 2 Speaker Replacement: step 8, image 1 of 1
    • Solder a speaker ribbon to the logic board.
    • Note: be careful to match the right polarity before you solder.
Chris
133 Reputation
5 Guides authored
Cal Poly, Team 12-35, Maness Spring 2011 Member of Cal Poly, Team 12-35, Maness Spring 2011
CPSU-MANESS-S11S12G35
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 2,115
