Samsung BD-D5500 Disc Tray Replacement
  1. Samsung BD-D5500 Disc Tray Replacement, Samsung BD-D5500 Disassembly: step 1, image 1 of 1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disc Tray Replacement: step 2, image 1 of 2 Samsung BD-D5500 Disc Tray Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Disc Tray Replacement, Disc Tray: step 3, image 1 of 1
    • To remove the disc hub all you have to do is remove the 4 screws holding it down.
  4. Samsung BD-D5500 Disc Tray Replacement: step 4, image 1 of 1
    • To replace the disc tray open the disk hub and unsnap the sides of the device.
  5. Samsung BD-D5500 Disc Tray Replacement: step 5, image 1 of 1
    • Locate the slider that reads open and close.
    • To open the disc tray slide it to the side that says open.
  6. Samsung BD-D5500 Disc Tray Replacement: step 6, image 1 of 1
    • Return it face up and the disc tray will slide out.
Brandon Nelson
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,044
