Samsung BD-E5400 Power Cord Replacement
  1. Samsung BD-E5400 Power Cord Replacement, Outer Cover: step 1, image 1 of 2 Samsung BD-E5400 Power Cord Replacement, Outer Cover: step 1, image 2 of 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Power Cord Replacement: step 2, image 1 of 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Power Cord Replacement, Power Cord: step 3, image 1 of 2 Samsung BD-E5400 Power Cord Replacement, Power Cord: step 3, image 2 of 2
    • Remove the two 8 mm long, #1 Phillips head screws.
    • Lift up the plastic component cover to remove and lay aside.
  4. Samsung BD-E5400 Power Cord Replacement: step 4, image 1 of 3 Samsung BD-E5400 Power Cord Replacement: step 4, image 2 of 3 Samsung BD-E5400 Power Cord Replacement: step 4, image 3 of 3
    • With the motherboard exposed, locate the point where the power cord is attached.
    • Separate the portion of the cord encased in the black grommet from the frame of the device.
    • Unplug the power cord from the motherboard.
Cameron Herring
306 Reputation
3 Guides authored
IUPUI, Team S1-G3, Arle Fall 2018 Member of IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 352
