Samsung BD-E5400 Wi-Fi Card Replacement
  1. Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: step 1, image 1 of 2 Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: step 1, image 2 of 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Wi-Fi Card Replacement: step 2, image 1 of 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: step 3, image 1 of 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: step 3, image 2 of 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: step 3, image 3 of 3
    • The Wi-Fi card is the light blue component circled in red.
    • Separate the body of the Wi-Fi card from the black plastic cover.
    • Unplug the wires of the Wi-Fi card from the motherboard.
Cameron Herring
306 Reputation
3 Guides authored
IUPUI, Team S1-G3, Arle Fall 2018 Member of IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Members
4 Guides authored
One Comment
I replaced my wifi card now none of the apps are working. I tried factory reset, and updating firmware nothing. Any ideas to get past this?
mike monroe - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 296
