Samsung BD-F5700 DC Power Board Replacement
  1. Samsung BD-F5700 DC Power Board Replacement, DC Power Board: step 1, image 1 of 1
    • Remove the three 10mm screws with a Phillips #0 screwdriver.
    • Pry the top off with a plastic opening tool.
  2. Samsung BD-F5700 DC Power Board Replacement: step 2, image 1 of 1
    • Remove the three screws holding down the cover with a Phillips #0 screwdriver.
  3. Samsung BD-F5700 DC Power Board Replacement: step 3, image 1 of 1
    • Lift up the power cord at its base to remove it.
  4. Samsung BD-F5700 DC Power Board Replacement: step 4, image 1 of 1
    • Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
  5. Samsung BD-F5700 DC Power Board Replacement: step 5, image 1 of 1
    • Remove the 7mm screw with a Phillips #1 screwdriver.
    • Grip the blue tab attached to the base and pull upwards.
  6. Samsung BD-F5700 DC Power Board Replacement: step 6, image 1 of 1
    • Grip the edges of the motherboard and pull upwards to remove.
samer odeh
313 Reputation
1 Guide authored
USF Tampa, Team S16-G4, Boczar Spring 2018 Member of USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 403
