Samsung BD-F5700 Disc Tray Replacement
  1. Samsung BD-F5700 Disc Tray  Replacement, Disc Tray: step 1, image 1 of 2 Samsung BD-F5700 Disc Tray  Replacement, Disc Tray: step 1, image 2 of 2
    • Remove the two 10mm screws with a Phillips #1 screwdriver.
    • Use the plastic prying tool to separate the top plastic casing from the bottom metal casing.
  2. Samsung BD-F5700 Disc Tray  Replacement: step 2, image 1 of 3 Samsung BD-F5700 Disc Tray  Replacement: step 2, image 2 of 3 Samsung BD-F5700 Disc Tray  Replacement: step 2, image 3 of 3
    • Grip the blue tab and pull upwards to remove the ribbon cable from the motherboard.
    • If it feels stuck, wiggle it while pulling gently to coerce it out.
  3. Samsung BD-F5700 Disc Tray  Replacement: step 3, image 1 of 1
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  4. Samsung BD-F5700 Disc Tray  Replacement: step 4, image 1 of 3 Samsung BD-F5700 Disc Tray  Replacement: step 4, image 2 of 3 Samsung BD-F5700 Disc Tray  Replacement: step 4, image 3 of 3
    • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
Livan Perez
303 Reputation
2 Guides authored
USF Tampa, Team S16-G4, Boczar Spring 2018 Member of USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 348
