Samsung BD-F5900 DVD Disc Tray Replacement
  1. Samsung BD-F5900 DVD Disc Tray Replacement, Top Cover: step 1, image 1 of 1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 DVD Disc Tray Replacement: step 2, image 1 of 1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 DVD Disc Tray Replacement, DVD Disc Tray: step 3, image 1 of 1
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  4. Samsung BD-F5900 DVD Disc Tray Replacement: step 4, image 1 of 1
    • Using a #1 Phillips head screwdriver, remove the two 7.5 mm screws (one not shown) near the front that secures the disc tray to the chassis.
  5. Samsung BD-F5900 DVD Disc Tray Replacement: step 5, image 1 of 1
    • Push two small prongs on either side of disc tray inwards and push disc tray forward.
  6. Samsung BD-F5900 DVD Disc Tray Replacement: step 6, image 1 of 1
    • Remove disc tray
Louis McKean
528 Reputation
5 Guides authored
USF Tampa, Team S1-G21, Cagle Fall 2017 Member of USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 679
