Samsung BD-F5900 WiFi Module Replacement
  1. Samsung BD-F5900 WiFi Module Replacement, Top Cover: step 1, image 1 of 1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 WiFi Module Replacement: step 2, image 1 of 1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 WiFi Module Replacement, WiFi Module: step 3, image 1 of 1
    • Disconnect the WiFi board cable connector from the main logic board
  4. Samsung BD-F5900 WiFi Module Replacement: step 4, image 1 of 1
    • Using a #1 Phillips head screwdriver, remove the 7.5 mm screw.
    • Slightly tilt the WiFi module sideways to remove from chassis.
Louis McKean
528 Reputation
5 Guides authored
USF Tampa, Team S1-G21, Cagle Fall 2017 Member of USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 222
