Samsung BD-F7500 Blu-ray Player Disc Tray Replacement
  1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: step 1, image 1 of 2 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: step 1, image 2 of 2
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 2, image 1 of 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 2, image 2 of 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 2, image 3 of 3
    • To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
    • Be careful not to tear the ribbon cables.
  3. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 3, image 1 of 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 3, image 2 of 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 3, image 3 of 3
    • Using a screwdriver with a #J1 bit, remove the two (2) 7 mm screws.
  4. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 4, image 1 of 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 4, image 2 of 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: step 4, image 3 of 3
    • Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
    • While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 701
