Samsung BD-JM57C Disc Drive Replacement
  1. Samsung BD-JM57C Disc Drive Replacement, Top Cover: step 1, image 1 of 2 Samsung BD-JM57C Disc Drive Replacement, Top Cover: step 1, image 2 of 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Disc Drive Replacement, Disc Drive: step 2, image 1 of 2 Samsung BD-JM57C Disc Drive Replacement, Disc Drive: step 2, image 2 of 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Disc Drive Replacement: step 3, image 1 of 2 Samsung BD-JM57C Disc Drive Replacement: step 3, image 2 of 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 14
All Time: 869
