Samsung BD-JM57C Wi-Fi Card Replacement
  1. Samsung BD-JM57C Wi-Fi Card Replacement, Top Cover: step 1, image 1 of 2 Samsung BD-JM57C Wi-Fi Card Replacement, Top Cover: step 1, image 2 of 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Wi-Fi Card Replacement, Disc Drive: step 2, image 1 of 2 Samsung BD-JM57C Wi-Fi Card Replacement, Disc Drive: step 2, image 2 of 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Wi-Fi Card Replacement: step 3, image 1 of 2 Samsung BD-JM57C Wi-Fi Card Replacement: step 3, image 2 of 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Wi-Fi Card Replacement, WiFi Card: step 4, image 1 of 2 Samsung BD-JM57C Wi-Fi Card Replacement, WiFi Card: step 4, image 2 of 2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 251
