Samsung Blast Keyboard Replacement
  1. Samsung Blast Keyboard Replacement, At a Glance: step 1, image 1 of 2 Samsung Blast Keyboard Replacement, At a Glance: step 1, image 2 of 2
    • Your phone should look like this before disassembly.
  2. Samsung Blast Keyboard Replacement, Battery Case Removal: step 2, image 1 of 2 Samsung Blast Keyboard Replacement, Battery Case Removal: step 2, image 2 of 2
    • Remove the battery cover by sliding the back panel up. This will expose the battery.
  3. Samsung Blast Keyboard Replacement, Remove Battery/Sim card: step 3, image 1 of 1
    • Lift up the top portion of the battery and pull it out.
    • Next, slide the sim card out of its socket and set it aside.
  4. Samsung Blast Keyboard Replacement, Back Case Removal: step 4, image 1 of 2 Samsung Blast Keyboard Replacement, Back Case Removal: step 4, image 2 of 2
    • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
    • The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Remove the case by prying around the edges.
    • Note the positions of button pads for reassembly.
  5. Samsung Blast Keyboard Replacement, Button Pads: step 5, image 1 of 2 Samsung Blast Keyboard Replacement, Button Pads: step 5, image 2 of 2
    • Remove the buttons for the camera and volume.
  6. Samsung Blast Keyboard Replacement, Motherboard Removal: step 6, image 1 of 3 Samsung Blast Keyboard Replacement, Motherboard Removal: step 6, image 2 of 3 Samsung Blast Keyboard Replacement, Motherboard Removal: step 6, image 3 of 3
    • Use a prying tool to detach the motherboard from main body.
    • Carefully detach the motherboard from the two connectors.
    • You could also use a pry tool for the second step.
    • Be careful with the motherboard as not to scrape or damage its components.
  7. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: step 7, image 1 of 2 Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: step 7, image 2 of 2
    • Slide the keyboard straight up to free it from its alignment pins.
    • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
Jordan Taylor
10 Reputation
1 Guide authored
Ohio State, Team 1-5, Buehl Spring 2014 Member of Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 300
