Samsung Blast Motherboard Replacement
  1. Samsung Blast Motherboard  Replacement, Motherboard: step 1, image 1 of 2 Samsung Blast Motherboard  Replacement, Motherboard: step 1, image 2 of 2
    • Remove the battery cover by pushing it upwards.
  2. Samsung Blast Motherboard  Replacement: step 2, image 1 of 1
    • Take out the battery.
  3. Samsung Blast Motherboard  Replacement: step 3, image 1 of 1
    • With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
    • You will not be able to completely remove the top two screws. Simply loosen them enough that you can still remove the cover.
  4. Samsung Blast Motherboard  Replacement: step 4, image 1 of 1
    • Pull off the back cover of the phone.
  5. Samsung Blast Motherboard  Replacement: step 5, image 1 of 2 Samsung Blast Motherboard  Replacement: step 5, image 2 of 2
    • Remove the volume and camera buttons by pulling them out.
    • Put the buttons aside until it is time to reassemble the phone.
  6. Samsung Blast Motherboard  Replacement: step 6, image 1 of 1
    • Use the small plastic opening tool to gently remove the motherboard from the rest of the phone.
  7. Samsung Blast Motherboard  Replacement: step 7, image 1 of 2 Samsung Blast Motherboard  Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
Paige Weinstein
1 Reputation
1 Guide authored
Ohio State, Team 1-5, Buehl Spring 2014 Member of Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 413
