Samsung CLP-300 Black Toner Transfer Unit Replacement
  1. Samsung CLP-300 Black Toner Transfer Unit Replacement, Black Toner Transfer Unit: step 1, image 1 of 1
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 2, image 1 of 1
    • Pull paper tray out and set aside.
  3. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 3, image 1 of 2 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 3, image 2 of 2
    • Open the front cover.
  4. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 4, image 1 of 1
    • Pull the waste toner container out of the printer using the handle.
    • Make sure to keep waste toner container upright to avoid spillage.
  5. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 5, image 1 of 3 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 5, image 2 of 3 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 5, image 3 of 3
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • At this point you can set the printer aside as you will only need the imaging unit to continue repair.
  6. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 6, image 1 of 2 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 6, image 2 of 2
    • Remove these two screws.
    • Do not expose imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
  7. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 7, image 1 of 1
    • Carefully pry plastic arm away from main unit.
  8. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 8, image 1 of 3 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 8, image 2 of 3 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 8, image 3 of 3
    • Carefully pry plastic from screw base so that the entire organic photo conductor piece slides open to the left.
    • When removing the organic photo conductor take care to not lose the small spring on the back left.
    • At this point you may want to put on plastic gloves to keep from staining hands with printer ink.
  9. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 9, image 1 of 2 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 9, image 2 of 2
    • Slide each toner transfer unit out separately, placing all aside except for the black toner transfer unit.
    • Keep toner rollers level to avoid toner spillage.
  10. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 10, image 1 of 3 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 10, image 2 of 3 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 10, image 3 of 3
    • Remove these five screws from the top of the black toner transfer unit.
    • Remove main and smaller z-shaped plates.
  11. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 11, image 1 of 2 Samsung CLP-300 Black Toner Transfer Unit Replacement: step 11, image 2 of 2
    • Remove these three screws from the right end of the toner transfer unit.
  12. Samsung CLP-300 Black Toner Transfer Unit Replacement: step 12, image 1 of 1
    • Remove plastic end piece.
    • Gently pull out black toner roller.
    • Insert new roller in place of old roller turning slightly to fit.
    • Be careful not to pinch small foam square when inserting new roller.
    • Cover new roller with toner by rotating roller by hand.
2 other people completed this guide.
Heather Howard
586 Reputation
4 Guides authored
2 Comments
I need more information pertaining step 8. In order to separate the parts, in which directions should the be moved first and where is the best point to apply force ?
Bernd Dreyer - Reply
I need more information for step 12: I removed the old roller. Unfortunately I don't know anymore how exactly the metal discs and the white plastic rings are placed.
Daniel Roller - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 3,358
