Samsung Captivate Camera Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Samsung Captivate Camera Assembly Replacement, Camera Assembly: step 1, image 1 of 2 Samsung Captivate Camera Assembly Replacement, Camera Assembly: step 1, image 2 of 2
    • Lift up the black NEC chip with attached ribbon cable using either a spudger or plastic opening tool.
    • Gently lift the camera assembly out of the plastic housing.
Drew Bentz
565 Reputation
5 Guides authored
Cal Poly, Team 20-25, Maness Fall 2011 Member of Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 523
