Samsung Captivate Glide Motherboard Replacement
  1. Samsung Captivate Glide Motherboard Replacement, Motherboard: step 1, image 1 of 3 Samsung Captivate Glide Motherboard Replacement, Motherboard: step 1, image 2 of 3 Samsung Captivate Glide Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Motherboard Replacement: step 2, image 1 of 2 Samsung Captivate Glide Motherboard Replacement: step 2, image 2 of 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Motherboard Replacement: step 3, image 1 of 2 Samsung Captivate Glide Motherboard Replacement: step 3, image 2 of 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Motherboard Replacement: step 4, image 1 of 3 Samsung Captivate Glide Motherboard Replacement: step 4, image 2 of 3 Samsung Captivate Glide Motherboard Replacement: step 4, image 3 of 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Motherboard Replacement: step 5, image 1 of 2 Samsung Captivate Glide Motherboard Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Motherboard Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Motherboard Replacement: step 7, image 1 of 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Motherboard Replacement: step 8, image 1 of 2 Samsung Captivate Glide Motherboard Replacement: step 8, image 2 of 2
    • Lift the motherboard out of the base of the phone.
Nicholas Mira
289 Reputation
2 Guides authored
USF Tampa, Team 5-3, Mcgee Fall 2014 Member of USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 773
