Samsung Captivate Glide QWERTY Keyboard Replacement
  1. Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: step 1, image 1 of 3 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: step 1, image 2 of 3 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide QWERTY Keyboard Replacement: step 2, image 1 of 2 Samsung Captivate Glide QWERTY Keyboard Replacement: step 2, image 2 of 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide QWERTY Keyboard Replacement: step 3, image 1 of 2 Samsung Captivate Glide QWERTY Keyboard Replacement: step 3, image 2 of 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide QWERTY Keyboard Replacement: step 4, image 1 of 3 Samsung Captivate Glide QWERTY Keyboard Replacement: step 4, image 2 of 3 Samsung Captivate Glide QWERTY Keyboard Replacement: step 4, image 3 of 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide QWERTY Keyboard Replacement: step 5, image 1 of 2 Samsung Captivate Glide QWERTY Keyboard Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide QWERTY Keyboard Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide QWERTY Keyboard Replacement: step 7, image 1 of 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide QWERTY Keyboard Replacement: step 8, image 1 of 2 Samsung Captivate Glide QWERTY Keyboard Replacement: step 8, image 2 of 2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: step 9, image 1 of 2 Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: step 9, image 2 of 2
    • Remove the eight screws using the #00 screw driver.
  10. Samsung Captivate Glide QWERTY Keyboard Replacement: step 10, image 1 of 2 Samsung Captivate Glide QWERTY Keyboard Replacement: step 10, image 2 of 2
    Buy
  11. Samsung Captivate Glide QWERTY Keyboard Replacement: step 11, image 1 of 1
    • Remove screws using the #00 screwdriver.
  12. Samsung Captivate Glide QWERTY Keyboard Replacement: step 12, image 1 of 1
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide QWERTY Keyboard Replacement: step 13, image 1 of 1
    • Lift the back plate.
    • To remove the attached flex cable, gently peel the flex cable connecting to the back plate.
    • Flex cable is attached to the back plate with an adhesive.
  14. Samsung Captivate Glide QWERTY Keyboard Replacement: step 14, image 1 of 3 Samsung Captivate Glide QWERTY Keyboard Replacement: step 14, image 2 of 3 Samsung Captivate Glide QWERTY Keyboard Replacement: step 14, image 3 of 3
    • Slide the flex cable through the slot.
    • Set the front plate down. Now you have free access to the keyboard.
  15. Samsung Captivate Glide QWERTY Keyboard Replacement: step 15, image 1 of 1
    • Manually lift the keyboard and replace with new keyboard.
    • Make sure the new keyboard is placed with the keyboard letters facing down, and the white back facing up.
2 other people completed this guide.
Jessica Martinez
260 Reputation
2 Guides authored
USF Tampa, Team 5-3, Mcgee Fall 2014 Member of USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 442
