Samsung Captivate Glide Screen Replacement
  1. Samsung Captivate Glide Screen Replacement, Motherboard: step 1, image 1 of 3 Samsung Captivate Glide Screen Replacement, Motherboard: step 1, image 2 of 3 Samsung Captivate Glide Screen Replacement, Motherboard: step 1, image 3 of 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Screen Replacement: step 2, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 2, image 2 of 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Screen Replacement: step 3, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 3, image 2 of 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Screen Replacement: step 4, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 4, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 4, image 3 of 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Screen Replacement: step 5, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Screen Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Screen Replacement: step 7, image 1 of 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Screen Replacement: step 8, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 8, image 2 of 2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide Screen Replacement, Screen: step 9, image 1 of 2 Samsung Captivate Glide Screen Replacement, Screen: step 9, image 2 of 2
    • Remove the eight screws with the #00 screwdriver.
  10. Samsung Captivate Glide Screen Replacement: step 10, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 10, image 2 of 2
    Buy
  11. Samsung Captivate Glide Screen Replacement: step 11, image 1 of 1
    • Remove screws with the #00 screwdriver.
  12. Samsung Captivate Glide Screen Replacement: step 12, image 1 of 1
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide Screen Replacement: step 13, image 1 of 1
    • Lift the back plate.
    • To remove to slide flex cable, gently peel back from the back plate and remove back plate.
  14. Samsung Captivate Glide Screen Replacement: step 14, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 14, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 14, image 3 of 3
    • Slide the flex cable through the slot. Be careful to not tear the cable.
    • Set the front plate down.
  15. Samsung Captivate Glide Screen Replacement: step 15, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 15, image 2 of 2
    • Remove the four corner screws using the #00 screwdriver.
  16. Samsung Captivate Glide Screen Replacement: step 16, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 16, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 16, image 3 of 3
    • Using the plastic opening tool, release all the clips on all four sides holding the screen assembly.
    • You can now remove the back plate by sliding the flex cable through the slot.
  17. Samsung Captivate Glide Screen Replacement: step 17, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 17, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 17, image 3 of 3
    • Use the plastic opening tool to release the main jaw connector, front speaker and camera.
  18. Samsung Captivate Glide Screen Replacement: step 18, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 18, image 2 of 2
    • By using the plastic opening tool you can release the keypad flex cable from the jaw connecter clamp.
  19. Samsung Captivate Glide Screen Replacement: step 19, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 19, image 2 of 2
    • Use a heat gun or blow dryer.
    • Heat the outside edges using quick movements for about 45 seconds.
  20. Samsung Captivate Glide Screen Replacement: step 20, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 20, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 20, image 3 of 3
    • Using the plastic opening tool to pry around the edges, release the touch screen from the screen frame.
  21. Samsung Captivate Glide Screen Replacement: step 21, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 21, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 21, image 3 of 3
    • While adhesive is still warm, use the plastic opening tool to gently remove the keyboard flex cable from the screen.
    • You can now replace the screen assembly.
Tyler Moore
139 Reputation
1 Guide authored
USF Tampa, Team 5-3, Mcgee Fall 2014 Member of USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,008
