Samsung Chromebook 2 Battery Replacement
  1. Samsung Chromebook 2 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure your Chromebook is turned off before you begin.
    • Set the labtop face down on a flat surface.
  2. Samsung Chromebook 2 Battery Replacement: step 2, image 1 of 3 Samsung Chromebook 2 Battery Replacement: step 2, image 2 of 3 Samsung Chromebook 2 Battery Replacement: step 2, image 3 of 3
    • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
  3. Samsung Chromebook 2 Battery Replacement: step 3, image 1 of 2 Samsung Chromebook 2 Battery Replacement: step 3, image 2 of 2
    • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
  4. Samsung Chromebook 2 Battery Replacement: step 4, image 1 of 2 Samsung Chromebook 2 Battery Replacement: step 4, image 2 of 2
    • Once the cover is loose, remove the back cover panel using your hands.
  5. Samsung Chromebook 2 Battery Replacement: step 5, image 1 of 2 Samsung Chromebook 2 Battery Replacement: step 5, image 2 of 2
    • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
  6. Samsung Chromebook 2 Battery Replacement: step 6, image 1 of 3 Samsung Chromebook 2 Battery Replacement: step 6, image 2 of 3 Samsung Chromebook 2 Battery Replacement: step 6, image 3 of 3
    • Disconnect the wire that connects the battery to the motherboard by pulling upward.
2 other people completed this guide.
Allan
115 Reputation
1 Guide authored
UW Tacoma, Team 1-3, Rose Winter 2016 Member of UW Tacoma, Team 1-3, Rose Winter 2016
UWT-ROSE-W16S1G3
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,465
