Samsung Chromebook 2 XE503c12 Trackpad Replacement
  1. Samsung Chromebook 2 XE503c12 Trackpad Replacement, Trackpad: step 1, image 1 of 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement, Trackpad: step 1, image 2 of 2
    • Turn the power off before beginning this step.
    • Most Chromebooks contain rubber circle pads on each of the four corners to cover the screws. In order to remove the rubber pads, simply use any opening tool.
    • Lay the Chromebook down so that the bottom cover is facing upward.
    • Using a Phillips #00 screwdriver, remove all nine 5.5 mm screws from the back cover.
  2. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 2, image 1 of 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 2, image 2 of 2
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
  3. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 3, image 1 of 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 3, image 2 of 2
    • Slowly pry off the back cover of the Chromebook.
    • Be gentle while prying to avoid breaking the back cover.
  4. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 4, image 1 of 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 4, image 2 of 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  5. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 5, image 1 of 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 5, image 2 of 2
    • Carefully lift the top of the battery then pull it away from you to remove it.
    • Some batteries may be attached via a battery connector. Disconnect the battery connector by simply pulling straight up at its base.
  6. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 6, image 1 of 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 6, image 2 of 2
    • Using a Phillips #00 screwdriver, remove all of the two screws keeping the trackpad in place.
  7. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 7, image 1 of 3 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 7, image 2 of 3 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 7, image 3 of 3
    • Gently remove the connector between the trackpad and the motherboard by pulling upward on it at the port.
  8. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 8, image 1 of 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 8, image 2 of 2
    • Using an opening tool, gently peel back the adhesive strip holding the trackpad in place.
  9. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 9, image 1 of 3 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 9, image 2 of 3 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 9, image 3 of 3
    • Using the opening tool, disconnect the metal trackpad support brackets.
    • Don't be afraid to use a moderate amount of force when prying the support brackets loose.
  10. Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 10, image 1 of 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: step 10, image 2 of 2
    • With the laptop slightly open, push the trackpad upwards at the rear, and pull it out from the bottom.
Shane Solomon
181 Reputation
1 Guide authored
IUPUI, Team S1-G1, Wilson Summer 2019 Member of IUPUI, Team S1-G1, Wilson Summer 2019
IUPUI-WILSON-SU19S1G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 184
