Samsung Chromebook 3 Daughterboard Replacement
  1. Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: step 1, image 1 of 2 Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: step 1, image 2 of 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Daughterboard Replacement: step 2, image 1 of 3 Samsung Chromebook 3 Daughterboard Replacement: step 2, image 2 of 3 Samsung Chromebook 3 Daughterboard Replacement: step 2, image 3 of 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Daughterboard Replacement: step 3, image 1 of 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Daughterboard Replacement, Battery: step 4, image 1 of 2 Samsung Chromebook 3 Daughterboard Replacement, Battery: step 4, image 2 of 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Daughterboard Replacement: step 5, image 1 of 2 Samsung Chromebook 3 Daughterboard Replacement: step 5, image 2 of 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Daughterboard Replacement: step 6, image 1 of 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: step 7, image 1 of 2 Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: step 7, image 2 of 2
    • Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
  8. Samsung Chromebook 3 Daughterboard Replacement: step 8, image 1 of 2 Samsung Chromebook 3 Daughterboard Replacement: step 8, image 2 of 2
    • Use a spudger to unhook the cable connecter from the speaker cable.
  9. Samsung Chromebook 3 Daughterboard Replacement: step 9, image 1 of 3 Samsung Chromebook 3 Daughterboard Replacement: step 9, image 2 of 3 Samsung Chromebook 3 Daughterboard Replacement: step 9, image 3 of 3
    • Pry the small coaxial cables upwards from the connecters on the wireless chip.
  10. Samsung Chromebook 3 Daughterboard Replacement: step 10, image 1 of 2 Samsung Chromebook 3 Daughterboard Replacement: step 10, image 2 of 2
    • Using the Phillips #00, unscrew one 4.6mm screw from the daughterboard.
  11. Samsung Chromebook 3 Daughterboard Replacement: step 11, image 1 of 3 Samsung Chromebook 3 Daughterboard Replacement: step 11, image 2 of 3 Samsung Chromebook 3 Daughterboard Replacement: step 11, image 3 of 3
    • Use a spudger to lift the gray plastic bar on the zif connecter up, then use your fingers to remove the cable ribbon.
  12. Samsung Chromebook 3 Daughterboard Replacement: step 12, image 1 of 1
    • Loosen the daughterboard from the USB port with a spudger as there is some adhesive underneath, and you're ready to remove the daughterboard.
3 other people completed this guide.
Sarah Westberg
24,271 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,221
