Samsung Chromebook 3 XE500C13-K05US Battery Replacement
  1. Samsung Chromebook 3 XE500C13-K05US Battery Replacement, Battery: step 1, image 1 of 1
    • Place the laptop back cover facing up to show the screws.
    • Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
  2. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 2, image 1 of 1
    • Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 3, image 1 of 2 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 3, image 2 of 2
    • Remove the cover showing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 4, image 1 of 2 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 4, image 2 of 2
    • Unscrew and remove the four screws that secure the battery.
  5. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 5, image 1 of 3 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 5, image 2 of 3 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 5, image 3 of 3
    • Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: step 6, image 1 of 1
    • Lift the battery out of the case to remove it from the laptop.
Yamaris Acosta
557 Reputation
3 Guides authored
Gateway, Team 4-4, Gonzalez Spring 2023 Member of Gateway, Team 4-4, Gonzalez Spring 2023
GCC-GONZALEZ-S23S4G4
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 177
