Samsung Chromebook Pro Battery Replacement
  1. Samsung Chromebook Pro Battery Replacement, Battery: step 1, image 1 of 2 Samsung Chromebook Pro Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
  2. Samsung Chromebook Pro Battery Replacement: step 2, image 1 of 3 Samsung Chromebook Pro Battery Replacement: step 2, image 2 of 3 Samsung Chromebook Pro Battery Replacement: step 2, image 3 of 3
    • Slide the plastic opening tool in a corner at a steep angle, and lift to remove the outer case.
  3. Samsung Chromebook Pro Battery Replacement: step 3, image 1 of 2 Samsung Chromebook Pro Battery Replacement: step 3, image 2 of 2
    • Remove the four 30 mm screws surrounding the battery with the JIS J000 screw bit.
  4. Samsung Chromebook Pro Battery Replacement: step 4, image 1 of 3 Samsung Chromebook Pro Battery Replacement: step 4, image 2 of 3 Samsung Chromebook Pro Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Lift the connecting wires to disconnect from the slot with the precision tweezers.
    • Lift battery to remove once the wire is disconnected.
3 other people completed this guide.
Amber Castro-Beltran
918 Reputation
5 Guides authored
One Comment
How do I know which battery to order? Is there a specific part number?
Will - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 2,804
