Samsung Chromebook Pro Speaker Replacement
  1. Samsung Chromebook Pro Speaker Replacement, Speaker: step 1, image 1 of 2 Samsung Chromebook Pro Speaker Replacement, Speaker: step 1, image 2 of 2
    • Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
  2. Samsung Chromebook Pro Speaker Replacement: step 2, image 1 of 3 Samsung Chromebook Pro Speaker Replacement: step 2, image 2 of 3 Samsung Chromebook Pro Speaker Replacement: step 2, image 3 of 3
    • Slide the plastic opening tool in a corner at a steep angle, and lift up to remove the outer case.
  3. Samsung Chromebook Pro Speaker Replacement: step 3, image 1 of 2 Samsung Chromebook Pro Speaker Replacement: step 3, image 2 of 2
    • Remove the one 40 mm silver screw using the JIS J000 screw bit.
  4. Samsung Chromebook Pro Speaker Replacement: step 4, image 1 of 3 Samsung Chromebook Pro Speaker Replacement: step 4, image 2 of 3 Samsung Chromebook Pro Speaker Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using the precision tweezers lift the wire to disconnect.
    • Remove the speaker.
Amber Castro-Beltran
918 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 527
