Samsung Chromebook Series 3 Charging Port Replacement
  1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: step 1, image 1 of 3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: step 1, image 2 of 3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: step 1, image 3 of 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Charging Port Replacement: step 2, image 1 of 3 Samsung Chromebook Series 3 Charging Port Replacement: step 2, image 2 of 3 Samsung Chromebook Series 3 Charging Port Replacement: step 2, image 3 of 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Charging Port Replacement: step 3, image 1 of 3 Samsung Chromebook Series 3 Charging Port Replacement: step 3, image 2 of 3 Samsung Chromebook Series 3 Charging Port Replacement: step 3, image 3 of 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Charging Port Replacement: step 4, image 1 of 3 Samsung Chromebook Series 3 Charging Port Replacement: step 4, image 2 of 3 Samsung Chromebook Series 3 Charging Port Replacement: step 4, image 3 of 3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: step 5, image 1 of 3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: step 5, image 2 of 3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: step 5, image 3 of 3
    • Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
  6. Samsung Chromebook Series 3 Charging Port Replacement: step 6, image 1 of 2 Samsung Chromebook Series 3 Charging Port Replacement: step 6, image 2 of 2
    • Remove the metal cover above the charging port module by pulling up and moving it slightly left.
  7. Samsung Chromebook Series 3 Charging Port Replacement: step 7, image 1 of 3 Samsung Chromebook Series 3 Charging Port Replacement: step 7, image 2 of 3 Samsung Chromebook Series 3 Charging Port Replacement: step 7, image 3 of 3
    • Pull out the charging port module connector by pulling directly up on it.
    • When reassembling, reconnect by positioning the connector directly above its original position and pushing down.
  8. Samsung Chromebook Series 3 Charging Port Replacement: step 8, image 1 of 2 Samsung Chromebook Series 3 Charging Port Replacement: step 8, image 2 of 2
    • You can now pull out the charging port module.
10 other people completed this guide.
Andrey Radchishin
1,860 Reputation
4 Guides authored
UWT Liner: Group 1 Member of UWT Liner: Group 1
Community
5 Members
8 Guides authored
2 Comments
What is the reference number for this charging port?
How to find it on ebay/other?
rafal - Reply
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
Andrey Radchishin -
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 37
All Time: 17,522
