Samsung Chromebook Series 3 Speaker Replacement
  1. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: step 1, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: step 1, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: step 1, image 3 of 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Speaker Replacement: step 2, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 2, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 2, image 3 of 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Speaker Replacement: step 3, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 3, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 3, image 3 of 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Speaker Replacement: step 4, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 4, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 4, image 3 of 3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Speaker Replacement, Battery: step 5, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement, Battery: step 5, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement, Battery: step 5, image 3 of 3
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Speaker Replacement: step 6, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 6, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 6, image 3 of 3
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Speaker Replacement: step 7, image 1 of 2 Samsung Chromebook Series 3 Speaker Replacement: step 7, image 2 of 2
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Speaker Replacement, Speaker: step 8, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement, Speaker: step 8, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement, Speaker: step 8, image 3 of 3
    • Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
  9. Samsung Chromebook Series 3 Speaker Replacement: step 9, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 9, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 9, image 3 of 3
    • Lift up the piece of tape covering the trackpad ribbon cable.
    • Lift up the lock on the trackpad ribbon cable using a plastic opening tool.
    • Disconnect the trackpad ribbon cable by pulling it out.
  10. Samsung Chromebook Series 3 Speaker Replacement: step 10, image 1 of 2 Samsung Chromebook Series 3 Speaker Replacement: step 10, image 2 of 2
    • Lift up the trackpad ribbon cable so that it is not covering the speaker wire.
    • Lift up the two pieces of metallic tape so that they no longer cover the speaker wire.
    • When reassembling the device, make sure to lay down the metallic tape in the same place it was prior to disassembly. The tape serves as a connector for certain electrical circuits that should not be disconnected.
  11. Samsung Chromebook Series 3 Speaker Replacement: step 11, image 1 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 11, image 2 of 3 Samsung Chromebook Series 3 Speaker Replacement: step 11, image 3 of 3
    • Unscrew the four 3.7 mm screws holding down the speakers using a Phillips #00 screwdriver.
  12. Samsung Chromebook Series 3 Speaker Replacement: step 12, image 1 of 2 Samsung Chromebook Series 3 Speaker Replacement: step 12, image 2 of 2
    • Pull the speakers up to remove them.
7 other people completed this guide.
Andrey Radchishin
1,860 Reputation
4 Guides authored
UWT Liner: Group 1 Member of UWT Liner: Group 1
Community
5 Members
8 Guides authored
One Comment
Many thanks.
Excellent guide .
Triumph Trident - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,611
