Samsung Chromebook XE550C22 Cooling Fan Replacement
Linh Luu
Linh Luu and 3 other contributors
Last updated on May 16, 2024
30 - 40 minutes
Moderate
Introduction
Go to step 1
After a period of time, the device might run too hot, this guide will help to clean up or replace the cooling fan for the Samsung Chromebook XE550C22.
Tools
Show more…
  1. Samsung Chromebook XE550C22 Cooling Fan Replacement, Back Panel: step 1, image 1 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement, Back Panel: step 1, image 2 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement, Back Panel: step 1, image 3 of 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Cooling Fan Replacement: step 2, image 1 of 2 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 2, image 2 of 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Cooling Fan Replacement: step 3, image 1 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 3, image 2 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 3, image 3 of 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Cooling Fan Replacement: step 4, image 1 of 2 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 4, image 2 of 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Cooling Fan Replacement, Battery: step 5, image 1 of 2 Samsung Chromebook XE550C22 Cooling Fan Replacement, Battery: step 5, image 2 of 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Cooling Fan Replacement: step 6, image 1 of 2 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 6, image 2 of 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 Cooling Fan Replacement, Cooling Fan: step 7, image 1 of 1
    • Locate the cooling fan and the heat sink on the top center of the Chromebook.
  8. Samsung Chromebook XE550C22 Cooling Fan Replacement: step 8, image 1 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 8, image 2 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 8, image 3 of 3
    Tool used on this step:
    $3.99
    • Rotate the Chromebook 180 degrees so the fan is closest to you, and locate the fan power cable.
    • Disconnect the fan cable from the motherboard with the angled tweezers.
    • Be gentle and do not pull out the fan cable with excessive force. It will result with a non-working cooling fan and a damaged wire.
  9. Samsung Chromebook XE550C22 Cooling Fan Replacement: step 9, image 1 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 9, image 2 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 9, image 3 of 3
    • Remove four identical 6mm screws from the heat sink labelled CPU using the J0 screwdriver.
    • Using your hands, gently lift up and pull away the heat sink.
  10. Samsung Chromebook XE550C22 Cooling Fan Replacement: step 10, image 1 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 10, image 2 of 3 Samsung Chromebook XE550C22 Cooling Fan Replacement: step 10, image 3 of 3
    • Remove the three identical 6mm screws from around the fan using the J0 screwdriver.
    • Using your hands, gently lift up the fan and pull it away from the laptop.
Linh Luu
312 Reputation
2 Guides authored
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 464
