Samsung Chromebook XE550C22 Wifi Card Replacement
  1. Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: step 1, image 1 of 3 Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: step 1, image 2 of 3 Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: step 1, image 3 of 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Wifi Card Replacement: step 2, image 1 of 2 Samsung Chromebook XE550C22 Wifi Card Replacement: step 2, image 2 of 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Wifi Card Replacement: step 3, image 1 of 3 Samsung Chromebook XE550C22 Wifi Card Replacement: step 3, image 2 of 3 Samsung Chromebook XE550C22 Wifi Card Replacement: step 3, image 3 of 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Wifi Card Replacement: step 4, image 1 of 2 Samsung Chromebook XE550C22 Wifi Card Replacement: step 4, image 2 of 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Wifi Card Replacement, Battery: step 5, image 1 of 2 Samsung Chromebook XE550C22 Wifi Card Replacement, Battery: step 5, image 2 of 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Wifi Card Replacement: step 6, image 1 of 2 Samsung Chromebook XE550C22 Wifi Card Replacement: step 6, image 2 of 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 Wifi Card Replacement, Wifi Card: step 7, image 1 of 1
    • Locate the wifi card on the top left of the Chromebook.
  8. Samsung Chromebook XE550C22 Wifi Card Replacement: step 8, image 1 of 3 Samsung Chromebook XE550C22 Wifi Card Replacement: step 8, image 2 of 3 Samsung Chromebook XE550C22 Wifi Card Replacement: step 8, image 3 of 3
    • Use only plastic tools for this step.
    • Use the spudger to detach the black and white cords from the wifi card.
  9. Samsung Chromebook XE550C22 Wifi Card Replacement: step 9, image 1 of 3 Samsung Chromebook XE550C22 Wifi Card Replacement: step 9, image 2 of 3 Samsung Chromebook XE550C22 Wifi Card Replacement: step 9, image 3 of 3
    • Remove the 6mm screw from the top right corner of the card using the J0 screwdriver.
    • The wifi card will "pop-up".
  10. Samsung Chromebook XE550C22 Wifi Card Replacement: step 10, image 1 of 2 Samsung Chromebook XE550C22 Wifi Card Replacement: step 10, image 2 of 2
    • Using your hands, gently remove the card up and away from the Chromebook.
5 other people completed this guide.
Linh Luu
312 Reputation
2 Guides authored
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 31
All Time: 4,098
