Samsung DV180F Repair Back control buttons Replacement
  1. Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: step 1, image 1 of 2 Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: step 1, image 2 of 2
    • Ensure the camera is turned off and battery is taken out before you begin.
    • Remove the two external screws from the camera using a Phillips 000 screwdriver.
  2. Samsung DV180F Repair Back control buttons Replacement: step 2, image 1 of 1
    • Insert a plastic opening tool in the gap between the camera body and back panel.
    • Pry along the right side of the camera to separate the back panel.
  3. Samsung DV180F Repair Back control buttons Replacement: step 3, image 1 of 1
    • Once the camera is open, remove the two internal screws using a Phillips 000 screwdriver.
  4. Samsung DV180F Repair Back control buttons Replacement: step 4, image 1 of 2 Samsung DV180F Repair Back control buttons Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to release the lock securing the ribbon receptor to the right side of the motherboard.
    • Ribbons have to be unlocked before removal to prevent damage.
  5. Samsung DV180F Repair Back control buttons Replacement: step 5, image 1 of 1
    • Gently lift the circuit board from the camera.
    • Remove the display ribbon receptor lock to remove back panel from the motherboard.
  6. Samsung DV180F Repair Back control buttons Replacement: step 6, image 1 of 2 Samsung DV180F Repair Back control buttons Replacement: step 6, image 2 of 2
    • Remove back display.
    • Replace the back button panel.
maria
244 Reputation
2 Guides authored
USF Tampa, Team 14-4, Eyestone Fall 2016 Member of USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 386
