Samsung DV300F Back Button Control Replacement
  1. Samsung DV300F Back Button Control Replacement, Front and Rear Casing: step 1, image 1 of 3 Samsung DV300F Back Button Control Replacement, Front and Rear Casing: step 1, image 2 of 3 Samsung DV300F Back Button Control Replacement, Front and Rear Casing: step 1, image 3 of 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Back Button Control Replacement: step 2, image 1 of 2 Samsung DV300F Back Button Control Replacement: step 2, image 2 of 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Back Button Control Replacement: step 3, image 1 of 3 Samsung DV300F Back Button Control Replacement: step 3, image 2 of 3 Samsung DV300F Back Button Control Replacement: step 3, image 3 of 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Back Button Control Replacement, Back Button Control: step 4, image 1 of 2 Samsung DV300F Back Button Control Replacement, Back Button Control: step 4, image 2 of 2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
3 other people completed this guide.
Timothy Gordon
841 Reputation
5 Guides authored
Baylor, Team 5-10, Williams Spring 2015 Member of Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 938
