Samsung DV300F Back LCD Screen Replacement
  1. Samsung DV300F Back LCD Screen Replacement, Front and Rear Casing: step 1, image 1 of 3 Samsung DV300F Back LCD Screen Replacement, Front and Rear Casing: step 1, image 2 of 3 Samsung DV300F Back LCD Screen Replacement, Front and Rear Casing: step 1, image 3 of 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Back LCD Screen Replacement: step 2, image 1 of 2 Samsung DV300F Back LCD Screen Replacement: step 2, image 2 of 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Back LCD Screen Replacement: step 3, image 1 of 3 Samsung DV300F Back LCD Screen Replacement: step 3, image 2 of 3 Samsung DV300F Back LCD Screen Replacement: step 3, image 3 of 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Back LCD Screen Replacement, Back LCD Screen: step 4, image 1 of 1
    • Remove the back LCD screen from its place carefully.
  5. Samsung DV300F Back LCD Screen Replacement: step 5, image 1 of 2 Samsung DV300F Back LCD Screen Replacement: step 5, image 2 of 2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
5 other people completed this guide.
Timothy Gordon
841 Reputation
5 Guides authored
Baylor, Team 5-10, Williams Spring 2015 Member of Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,473
