Samsung DV300F Front LCD Screen Replacement
Timothy Gordon
Timothy Gordon and 7 other contributors
Last updated on October 23, 2020
5 - 10 minutes
Moderate
Action Shots
Introduction
Go to step 1
This guide describes how to replace the Samsung DV300F front LCD screen. There are many small screws involved with this process.
If your Samsung DV300F is displaying black spots, discolored areas, or blurred sections , it is time to replace the LCD screen.
Tools
  1. Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: step 1, image 1 of 3 Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: step 1, image 2 of 3 Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: step 1, image 3 of 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Front LCD Screen Replacement: step 2, image 1 of 2 Samsung DV300F Front LCD Screen Replacement: step 2, image 2 of 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Front LCD Screen Replacement: step 3, image 1 of 3 Samsung DV300F Front LCD Screen Replacement: step 3, image 2 of 3 Samsung DV300F Front LCD Screen Replacement: step 3, image 3 of 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Front LCD Screen Replacement, Back Button Control: step 4, image 1 of 2 Samsung DV300F Front LCD Screen Replacement, Back Button Control: step 4, image 2 of 2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Front LCD Screen Replacement, Back LCD Screen: step 5, image 1 of 1
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Front LCD Screen Replacement: step 6, image 1 of 2 Samsung DV300F Front LCD Screen Replacement: step 6, image 2 of 2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Front LCD Screen Replacement, Front LCD Screen: step 7, image 1 of 2 Samsung DV300F Front LCD Screen Replacement, Front LCD Screen: step 7, image 2 of 2
    • Unscrew the 3 silver 4.5 mm screws from the circuit board using a Phillips #0 screwdriver.
    • Remove the circuit board cover.
  8. Samsung DV300F Front LCD Screen Replacement: step 8, image 1 of 3 Samsung DV300F Front LCD Screen Replacement: step 8, image 2 of 3 Samsung DV300F Front LCD Screen Replacement: step 8, image 3 of 3
    • Flip the black tab where the front LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the front LCD screen from the circuit board.
    • You can do this easily with your fingers.
    • Remove the front LCD screen from the front of the camera.
Timothy Gordon
820 Reputation
5 Guides authored
Baylor, Team 5-10, Williams Spring 2015 Member of Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 12
All Time: 874
