Samsung DV300F Lens Replacement
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: step 1, image 1 of 3 Samsung DV300F Lens Replacement, Front and Rear Casing: step 1, image 2 of 3 Samsung DV300F Lens Replacement, Front and Rear Casing: step 1, image 3 of 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Lens Replacement: step 2, image 1 of 2 Samsung DV300F Lens Replacement: step 2, image 2 of 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Lens Replacement: step 3, image 1 of 3 Samsung DV300F Lens Replacement: step 3, image 2 of 3 Samsung DV300F Lens Replacement: step 3, image 3 of 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: step 4, image 1 of 2 Samsung DV300F Lens Replacement, Back Button Control: step 4, image 2 of 2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: step 5, image 1 of 1
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Lens Replacement: step 6, image 1 of 2 Samsung DV300F Lens Replacement: step 6, image 2 of 2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: step 7, image 1 of 2 Samsung DV300F Lens Replacement, Lens: step 7, image 2 of 2
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: step 8, image 1 of 2 Samsung DV300F Lens Replacement: step 8, image 2 of 2
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
6 other people completed this guide.
Timothy Gordon
841 Reputation
5 Guides authored
Baylor, Team 5-10, Williams Spring 2015 Member of Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Members
10 Guides authored
1 Guide Comment
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - Reply
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 68
All Time: 2,865
