Samsung DVD-HD850 Player Disk Tray Replacement
  1. Samsung DVD-HD850 Player Disk Tray Replacement, Locate and Remove The Disk Tray: step 1, image 1 of 1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  2. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Data Strips: step 2, image 1 of 1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  3. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: step 3, image 1 of 3 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: step 3, image 2 of 3 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: step 3, image 3 of 3
    • As noted by the red circles, locate and remove the screws one at a time
  4. Samsung DVD-HD850 Player Disk Tray Replacement, Disk Tray Removal: step 4, image 1 of 1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  5. Samsung DVD-HD850 Player Disk Tray Replacement, Success!: step 5, image 1 of 1
    • Congrats! You have sucessfully have taken out the disk drive
Carlos
354 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 16
All Time: 572
