Samsung DVD-HD850 Player Rubber Band Replacement
  1. Samsung DVD-HD850 Player Rubber Band Replacement, Cover: step 1, image 1 of 1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Rubber Band Replacement, Locate and remove screws: step 2, image 1 of 1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Rubber Band Replacement, Remove Cover: step 3, image 1 of 1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  4. Samsung DVD-HD850 Player Rubber Band Replacement, Locate and Remove The Disk Tray: step 4, image 1 of 1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  5. Samsung DVD-HD850 Player Rubber Band Replacement, Removing The Data Strips: step 5, image 1 of 1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  6. Samsung DVD-HD850 Player Rubber Band Replacement, Removing The Screws: step 6, image 1 of 3 Samsung DVD-HD850 Player Rubber Band Replacement, Removing The Screws: step 6, image 2 of 3 Samsung DVD-HD850 Player Rubber Band Replacement, Removing The Screws: step 6, image 3 of 3
    • As noted by the red circles, locate and remove the screws one at a time
  7. Samsung DVD-HD850 Player Rubber Band Replacement, Disk Tray Removal: step 7, image 1 of 1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  8. Samsung DVD-HD850 Player Rubber Band Replacement, Success!: step 8, image 1 of 1
    • Congrats! You have sucessfully have taken out the disk drive
  9. Samsung DVD-HD850 Player Rubber Band Replacement, Disk Tray Preparation: step 9, image 1 of 1
    • remember to never connect the device to a power source when working on electrical components on/in the device
    • It it recommended to buy the Elastic Rubber Band needed for this repair guide first, you can buy the band at this link: http://www.ebay.com/itm/100-Latex-Elasti... the name of the specific rubber band for this device is located at the top of this repair guide
  10. Samsung DVD-HD850 Player Rubber Band Replacement, Locate the White Spindle: step 10, image 1 of 1
    • Locate the small white spindle on the face of the tray (the face is where the DVD name is edged on the front) and turn the spindle counterclockwise (with the screw driver listed under "tools" or something similar) until the tray begins to open
  11. Samsung DVD-HD850 Player Rubber Band Replacement, Opening The Disk Tray: step 11, image 1 of 2 Samsung DVD-HD850 Player Rubber Band Replacement, Opening The Disk Tray: step 11, image 2 of 2
    • Once the tray is opened, locate the rubber band, as noted by the blue box, and remove and replace it by pulling it out of the mechanism
  12. Samsung DVD-HD850 Player Rubber Band Replacement, Rubber Band Replacement: step 12, image 1 of 2 Samsung DVD-HD850 Player Rubber Band Replacement, Rubber Band Replacement: step 12, image 2 of 2
    • Once removed, replace the band with one you have bought, or have on-hand and and insert it into its rightful place
Carlos
354 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 678
