Samsung DVD-P230 LCD Screen Replacement
  1. Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: step 1, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: step 1, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: step 1, image 3 of 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Samsung DVD-P230 LCD Screen Replacement: step 2, image 1 of 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Samsung DVD-P230 LCD Screen Replacement: step 3, image 1 of 1
    • Unscrew the 3 screws in the back.
  4. Samsung DVD-P230 LCD Screen Replacement: step 4, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 4, image 2 of 2
    • Pull the outer case upward and then towards you.
  5. Samsung DVD-P230 LCD Screen Replacement: step 5, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement: step 5, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement: step 5, image 3 of 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Samsung DVD-P230 LCD Screen Replacement: step 6, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 6, image 2 of 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Samsung DVD-P230 LCD Screen Replacement, Power Cord: step 7, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement, Power Cord: step 7, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement, Power Cord: step 7, image 3 of 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Samsung DVD-P230 LCD Screen Replacement, Tray: step 8, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement, Tray: step 8, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement, Tray: step 8, image 3 of 3
    • Remove the three screws holding in the DVD tray
  9. Samsung DVD-P230 LCD Screen Replacement: step 9, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 9, image 2 of 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Samsung DVD-P230 LCD Screen Replacement: step 10, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 10, image 2 of 2
    • Gently lift the DVD tray off of the motherboard.
  11. Samsung DVD-P230 LCD Screen Replacement, Motherboard: step 11, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement, Motherboard: step 11, image 2 of 2
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
  12. Samsung DVD-P230 LCD Screen Replacement: step 12, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement: step 12, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement: step 12, image 3 of 3
    • Disconnect the wires and ribbon by pulling them out of their respective connections
  13. Samsung DVD-P230 LCD Screen Replacement: step 13, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 13, image 2 of 2
    • Lift board up and out of the lower case
  14. Samsung DVD-P230 LCD Screen Replacement, LCD Screen: step 14, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement, LCD Screen: step 14, image 2 of 2
    • The LCD screen has pins attaching it to the motherboard. Flip the motherboard over.
    • De-solder LCD screen pins from the motherboard.
    • Pinch black tabs to remove LCD screen from motherboard.
    • Solder the new LCD screen pins into motherboard.
Evan Domingue
410 Reputation
3 Guides authored
Cal Poly, Team 3-30, Regan Winter 2011 Member of Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 3,007
