Samsung Epic 4G Keyboard Replacement
  1. Samsung Epic 4G Keyboard Replacement, Phone Case: step 1, image 1 of 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Keyboard Replacement: step 2, image 1 of 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Keyboard Replacement, Battery: step 3, image 1 of 1
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Keyboard Replacement, Removing the Memory Card:: step 4, image 1 of 1
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Keyboard Replacement, Removing the Back Housing: step 5, image 1 of 2 Samsung Epic 4G Keyboard Replacement, Removing the Back Housing: step 5, image 2 of 2
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Keyboard Replacement, Removing the Power Button: step 6, image 1 of 2 Samsung Epic 4G Keyboard Replacement, Removing the Power Button: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
  7. Samsung Epic 4G Keyboard Replacement, Micro USB Port: step 7, image 1 of 1
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
  8. Samsung Epic 4G Keyboard Replacement, Removing the Antenna Assembly: step 8, image 1 of 2 Samsung Epic 4G Keyboard Replacement, Removing the Antenna Assembly: step 8, image 2 of 2
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
  9. Samsung Epic 4G Keyboard Replacement, Removing the Flex Cable: step 9, image 1 of 2 Samsung Epic 4G Keyboard Replacement, Removing the Flex Cable: step 9, image 2 of 2
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
  10. Samsung Epic 4G Keyboard Replacement: step 10, image 1 of 1
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
  11. Samsung Epic 4G Keyboard Replacement, Camera Lens: step 11, image 1 of 1
    • Remove and replace the camera lens with a new one from a manufacturer.
  12. Samsung Epic 4G Keyboard Replacement, Keyboard: step 12, image 1 of 2 Samsung Epic 4G Keyboard Replacement, Keyboard: step 12, image 2 of 2
    • Remove the white label sticker.
    • Remove the four screws on the left side of the device with a small Phillips screwdriver.
    • Two of the screws are found behind the white label, and two are found directly above the label.
  13. Samsung Epic 4G Keyboard Replacement: step 13, image 1 of 3 Samsung Epic 4G Keyboard Replacement: step 13, image 2 of 3 Samsung Epic 4G Keyboard Replacement: step 13, image 3 of 3
    • Lift up and loosen the metallic silver trim on the perimeter of the phone using a nylon spudger.
    • Carefully remove the gray mid-plate with the spudger.
    • Take extra caution to not destroy the QWERTY keyboard, which lies directly behind the mid-plate. Do not slide open the phone at this time.
    • The mid-plate should be completely removed from the keyboard and separated from the device.
    • At this point, you may remove the original QWERTY keyboard and install a replacement keyboard. Installation is the reverse of removal.
3 other people completed this guide.
Katie Zombro
250 Reputation
1 Guide authored
Cal Poly, Team 24-25, Regan Fall 2012 Member of Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,910
