Samsung Epic 4G Power Button Replacement
  1. Samsung Epic 4G Power Button Replacement, Phone Case: step 1, image 1 of 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Power Button Replacement: step 2, image 1 of 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Power Button Replacement, Battery: step 3, image 1 of 1
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: step 4, image 1 of 1
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: step 5, image 1 of 2 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: step 5, image 2 of 2
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: step 6, image 1 of 2 Samsung Epic 4G Power Button Replacement, Removing the Power Button: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
Andrew Cunningham
273 Reputation
6 Guides authored
Cal Poly, Team 24-25, Regan Fall 2012 Member of Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,296
