Samsung Epic 4G Touch microSD Card Replacement
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: step 1, image 1 of 2 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: step 1, image 2 of 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: step 2, image 1 of 2 Samsung Epic 4G Touch microSD Card Replacement: step 2, image 2 of 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: step 3, image 1 of 2 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: step 3, image 2 of 2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: step 4, image 1 of 1
    • Pull the microSD card away from its slot.
3 other people completed this guide.
2 Comments
Uhh.... my Australian SGSII looks different to this...
Bonj - Reply
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 4,388
