Samsung Epix Keyboard Replacement
  1. Samsung Epix Keyboard Replacement, Battery: step 1, image 1 of 1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix Keyboard Replacement: step 2, image 1 of 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Keyboard Replacement: step 4, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Keyboard Replacement: step 5, image 1 of 2 Samsung Epix Keyboard Replacement: step 5, image 2 of 2
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Keyboard Replacement: step 6, image 1 of 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable located in the bottom right side of the motherboard.
  7. Samsung Epix Keyboard Replacement: step 7, image 1 of 1
    • Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully remove the ribbon.
  8. Samsung Epix Keyboard Replacement: step 8, image 1 of 1
    • Remove the front faceplate.
  9. Samsung Epix Keyboard Replacement: step 9, image 1 of 1
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove.
Chris
23 Reputation
1 Guide authored
Cal Poly, Team 15-15, Regan Spring 2011 Member of Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,664
