Samsung Eternity Camera Replacement
    • Remove the back battery cover.
  1. Samsung Eternity Camera Replacement: step 2, image 1 of 1
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Camera Replacement: step 3, image 1 of 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Camera Replacement: step 4, image 1 of 2 Samsung Eternity Camera Replacement: step 4, image 2 of 2
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Camera Replacement, Camera: step 5, image 1 of 1
    • Peel off the Identification sticker.
  5. Samsung Eternity Camera Replacement: step 6, image 1 of 1
    • Peel the button sensor on the side of the motherboard off of the case.
  6. Samsung Eternity Camera Replacement: step 7, image 1 of 1
    • Pop the black hinged-release lever toward its ribbon, then slide the ribbon out.
  7. Samsung Eternity Camera Replacement: step 8, image 1 of 1
    • Peel up the camera attachment.
  8. Samsung Eternity Camera Replacement: step 9, image 1 of 1
    • You will now be able to replace the Camera component with a new part.
Michelle Haddock
45 Reputation
3 Guides authored
Cal Poly, Team 15-11, Regan Spring 2011 Member of Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,873
