Samsung Eternity Digitizer and Screen Replacement
Heather Behrend
Heather Behrend and 8 other contributors
Last updated on January 13, 2025
No estimate
Moderate
Incorrect Tools
Needs More Images
Action Shots
Better Introduction
Missing Details
Introduction
Go to step 1
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's digitizer and screen.
Tools
Show more…
    • Remove the back battery cover.
  1. Samsung Eternity Digitizer and Screen Replacement: step 2, image 1 of 1
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Digitizer and Screen Replacement: step 3, image 1 of 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Digitizer and Screen Replacement: step 4, image 1 of 2 Samsung Eternity Digitizer and Screen Replacement: step 4, image 2 of 2
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Digitizer and Screen Replacement, Motherboard: step 5, image 1 of 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Digitizer and Screen Replacement: step 6, image 1 of 3 Samsung Eternity Digitizer and Screen Replacement: step 6, image 2 of 3 Samsung Eternity Digitizer and Screen Replacement: step 6, image 3 of 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Digitizer and Screen Replacement: step 7, image 1 of 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Digitizer and Screen Replacement: step 8, image 1 of 1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Digitizer and Screen Replacement: step 9, image 1 of 3 Samsung Eternity Digitizer and Screen Replacement: step 9, image 2 of 3 Samsung Eternity Digitizer and Screen Replacement: step 9, image 3 of 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Digitizer and Screen Replacement: step 10, image 1 of 1
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Digitizer and Screen Replacement, Digitizer and Screen: step 11, image 1 of 1
    • Flip the phone over so you are looking at the front screen of the phone.
  11. Samsung Eternity Digitizer and Screen Replacement: step 12, image 1 of 3 Samsung Eternity Digitizer and Screen Replacement: step 12, image 2 of 3 Samsung Eternity Digitizer and Screen Replacement: step 12, image 3 of 3
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Digitizer and Screen Replacement: step 13, image 1 of 3 Samsung Eternity Digitizer and Screen Replacement: step 13, image 2 of 3 Samsung Eternity Digitizer and Screen Replacement: step 13, image 3 of 3
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
4 other people completed this guide.
Heather Behrend
133 Reputation
1 Guide authored
Cal Poly, Team 15-11, Regan Spring 2011 Member of Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Members
14 Guides authored
3 Comments
You did not mention how to glue the digitizer to LCD. That is a very important step.
cashyapan - Reply
Do these steps also work for the Samsung Eternity 2?
Brian Coukis The 90's Kid! - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 6,906
