Samsung Eternity Input Jack Replacement
    • Remove the back battery cover.
  1. Samsung Eternity Input Jack Replacement: step 2, image 1 of 1
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Input Jack Replacement: step 3, image 1 of 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Input Jack Replacement: step 4, image 1 of 2 Samsung Eternity Input Jack Replacement: step 4, image 2 of 2
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Input Jack Replacement, Input Jack: step 5, image 1 of 1
    • Peel off the Identification sticker
  5. Samsung Eternity Input Jack Replacement: step 6, image 1 of 1
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  6. Samsung Eternity Input Jack Replacement: step 7, image 1 of 1
    • Pop the speaker plug out of its socket.
  7. Samsung Eternity Input Jack Replacement: step 8, image 1 of 1
    • Peel the button sensor off the top of the case.
  8. Samsung Eternity Input Jack Replacement: step 9, image 1 of 1
    • Peel the Input jack assembly out of the case.
Sven
52 Reputation
1 Guide authored
Cal Poly, Team 15-11, Regan Spring 2011 Member of Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,539
