Samsung Exhibit II 4G Loudspeaker Replacement
  1. Samsung Exhibit II 4G Loudspeaker Replacement, Battery: step 1, image 1 of 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Loudspeaker Replacement: step 2, image 1 of 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Loudspeaker Replacement, Top Rear Housing Cover: step 3, image 1 of 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Loudspeaker Replacement: step 4, image 1 of 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Loudspeaker Replacement: step 5, image 1 of 2 Samsung Exhibit II 4G Loudspeaker Replacement: step 5, image 2 of 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Loudspeaker Replacement: step 6, image 1 of 3 Samsung Exhibit II 4G Loudspeaker Replacement: step 6, image 2 of 3 Samsung Exhibit II 4G Loudspeaker Replacement: step 6, image 3 of 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Loudspeaker Replacement, Midframe: step 7, image 1 of 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Loudspeaker Replacement: step 8, image 1 of 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Loudspeaker Replacement: step 9, image 1 of 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Loudspeaker Replacement: step 10, image 1 of 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: step 11, image 1 of 3 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: step 11, image 2 of 3 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: step 11, image 3 of 3
    • Position Back Panel Assembly so the internal Loudspeaker unit is facing up.
    • With your index fingers and thumbs, grasp the Back Panel Assembly near the Loudspeaker.
    • Twist your palms inward to apply pressure against your index fingers.
    • The Loudspeaker will easily pop out.
David R
1,152 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 312
