Samsung Exhibit II 4G Top Rear Housing Cover Replacement
  1. Samsung Exhibit II 4G Top Rear Housing Cover Replacement, Battery: step 1, image 1 of 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: step 2, image 1 of 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Top Rear Housing Cover Replacement, Top Rear Housing Cover: step 3, image 1 of 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: step 4, image 1 of 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: step 5, image 1 of 2 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: step 5, image 2 of 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: step 6, image 1 of 3 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: step 6, image 2 of 3 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: step 6, image 3 of 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
2 other people completed this guide.
David R
1,152 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 25
All Time: 291
